We currently have a job where we need to design some 904L piping. The request is to use this material for a design of 300°C.
B16.5 p,T-ratings are OK for 300°C and even good up to 375°C. ASME II-D (Metric, 2019, page 248, lines 20÷27) lists N08904 up to 371°C.
B31.3, the piping code we're working to, 'limits' this material to a max. use temp of 260°C per table A-1M. Although such limits in B31.3 are not as hard as e.g. those in IID, these limits (afaik) are usually limited by some sort pf material degradation mechanisms that comes into play at a certain temperature.
I wondered if anyone has any idea or thoughts about any possible material degradation mechanism or the like, for 904L in this range, that could limit the material's 'safe' temperature range.
Huub
- You never get what you expect, you only get what you inspect.
Huub
