Hi All,
Need help with choosing the correct material modifier for press fit holes (H7), while using a positional tolerance.
Need to position TWO HOLE PATTERN (Diagonally placed on a rectangular plate) with a position tolerance, Dowel pins to be fitted to these holes, these dowel pins(m6) will be used to locate the top plate which fits on this.
> for positioning these holes, can I use Maximum material modifier for the pos.tolerance? or is this be with RFS ?
> if we use RFS how to distribute the tolerance for position, and still achieve the desired fit.
Please do the needful.
Thank you
Thank you
