Maximum Velocities for Pnuematic Conveying
jka1977
Chemical
Jun 12, 2008
Dear all:
I am designing a new dilute phase vacuum pnuematic conveying system which will utilize some existing transport piping. One of the objectives for the new design is to improve the system capacity. I am, however, concerned about causing excessive wear in the existing piping system due to the increased transport velocities.
Therefore, I am searching for any available info on maximum recommended air velocities for these types of systems. Can anyone provide some guidance based on past experience or suggest a good reference to consult?
Depends on the abrasive nature of the product conveyed, which you haven't specified...
I had figured as much. The product conveyed is tobacco dust (not particularly abrasive). It is not atypical to convey this material at 6000-6500 FPM with no major issues but the systems I'm familiar with run intermittently. This application is a housekeeping vac system so even though the solids loading is light, it will run continously. Therefore, I want to be cautious about exceeding the above range.
