MBR Permeate conductivity high
Sajan K
Chemical
Jan 3, 2024
4
Hi All
Ours is Grain industry and we are receiving high BOD ,COD approx 3000-4000,also conductivity, normally our feed water conductivity is 1000,but after the MBR treatment conductivity increases to 3000,which gives a high RO conductivity as well, Just wondering what causing the MBR permeate conductivity increase?is anything i can do to reduce the MBR conductivity? I am dosing Sodium hypochlorite to the MBR permeate tank, no other chemical to MBR.
Thanks in advance
Sajan
The conductivity should drop across the MBR.
Get lab tests done in distilled water with a series of hypochlorite concentrations, at your service temperature.
Thanks, I just got the test results and looks like Sulphate level is gone really high on MBR permeate(450g/L) just wondering what cause the sulphate increase?
