DIPA is a secondary amine while MDEA is a tertiary amine. The latter reacts more slowly with CO2 forming bicarbonate. With DIPA, CO2 forms carbamate. MDEA is also considered more selective towards H2S than to CO2 resulting in a better composition of the feed to a sulfur recovery unit. It is true that DIPA degrades severely wiht CO2 to form 3-(2-hydroxypropyl) 5-methyl oxazolidone, which doesn't have acid gas removal properties.
Although I cannot give an explanation of the reasons of your plant's performance, I can submit herebelow a published comparison between the two amines:
DIPA MDEA
Molecular weight 133.2 119.2
Typ. concentration, mass% 30-32 35-50
Typ. lean loading, mol/mol 0.05 0.01
Typ. rich liquid loading, mol/mol 0.15 0.12
Typ. rich gas loading, mol/mol 0.40 0.45
Typ. steam use lb/gal 1.1 1.0
Pure amine relative price 0.95 1.0
Heat of reaction with CO2, Btu/lb 550 475
Heat of reaction with H2S, Btu/lb 475 455
The amine capacity at 200 lb-mol/h acid gas:
Acid gas pickup, mol/mol 0.35 0.44
Concentration, mass% 32 50
Circulation rate, gpm 476 217
Estimated steam required, lb/h 31,400 13,000
General notes:
1. Upon purifying and reclaiming, carbon absorption and filtration are needed to remove not only contaminants before they react with amine but also solids that may stabilize foam.
2. High contactor temperatures reduce amine effectiveness in absorbing acid gas. These temperatures are determined by: a. the incoming lean solution; b. the incoming gas stream; c. the amine content in the circulating solution;
a high amine content solution contains less mass to distribute the heat of reaction, thereby increasing the contactor temperature. Addition of water to the amine solution (diluting it) cools the contactor and reduces potential corrosivity.
3. On the other hand increasing amine concentration will:
1. reduce circulation rate (less water in the solution)
2. increase corrosivity due to the higher boiling temperature which also increases degradation and utility costs
3. increase hydrocarbons' pickup because due to lower water concentration the affinity to hydrocarbons increases
4. increase solvent vaporization losses
5. increase foaming tendency due to increased organic content.
Thus the benefits of decreased pumping costs should be compared with increased amine losses, foaming and possible corrosion.
Good luck.
