For the LP..
Fuel Gas Drum, MDMT (design)is -2 Deg C (27 Deg F)…..with Shell / Head Materials in SA516-60N + S5 + HIC..with Shell thickness (20 mm Top …24 mm Middle…20 mm Bottom and 24 mm thick Heads)
As we understand, SA 516 -60 material can sustain temperature upto (-29 Deg C)
Would like to know, the following
1. Whether the lower design temperature of vessel can be considered as (-29 Deg C )?...if not , why?
2. What is the minimum temperature (with the existing construction), the vessel can be subjected to?
