bc1080
- Sep 11, 2015
- 20
We are comparing several NAS bolt options as a replacement for an existing joint on a fairly short schedule and am looking into one we haven't used before. I noticed that on the NAS624-644 bolt spec sheet data table there is a header "fatigue load lbs +/-2%" with "high" and "low" columns of values under it for each fastener size. I have never seen this exact terminology used before and am trying to figure out how to interpret this data. First impression was that it was somehow related to the endurance limit or some pseudo-infinite life loading or performance in a testing sample set. But the high and low threw me, unless that is generic for "high/low cycles" or something like that. I am not aware if there is some sort of standardized bolt test for this that they might be referencing, the spec does mention fatigue test values. There is a huge range between high and low values, so I wouldn't think they would be acceptance values.
Ex: NAS638 (1-1/8")
high = 70,300, low = 7,030
They all seem to be 10x apart like that (equation based?)
Really at the heart of it we are just trying to qualitatively (numerically if possible, but very hard to find good, comparative values) compare the ductility/toughness/fatigue properties of A286 fasteners at 160ksi ultimate with Grade 8 type fasteners and the 180-200 ksi alloy steel bolts (like the NAS spec above). It's been somewhat hard to find consistent values for A286 in particular as I have found fairly wide variations of reported properties between difference references/vendors.
Ex: NAS638 (1-1/8")
