Measure parts edge
stormloader
Aerospace
Oct 16, 2014
15
Hello everyone,
Is there a "quick" way of measuring complete edge of a complex part? (or any workaround)
I have unfolded sheet metal part and need to know outer edge length so i can determine how much time we need for machining...
Thanks.
you can make a boundary in GSD and measure it.
I did the Tangent Continuity extraction but it still doesnt measure my full edge, just till the next radius,
can you explain what u meant by "then use Measure Item(with perimeter set on)." ?
Fernando,
thanks for the help,
i did what you wrote only problem is it counts in all pilot holes i have on the surface but still, i can work with this.
Thank you...
pilot holes is not a problem..when you use boundary choose complete or point continuity. you get the message from catia do you want to keep all elements or near/far..choose near/far.another dialog box appears.choose as reference outside boundary.done and now you can mesure item (boundary)
 http://files.engineering.com/getfile.aspx?folder=28b7b0c3-8a20-4e92-a0bb-e8822c4b7eef&file=Untitled.jpg
