Measure radius 2
TiagoFigueiredo
Industrial
May 22, 2013
497
Is there any fast way to measure the following radius?
I have an way, but too much mouse clicking!
Tiago Figueiredo
Tooling Engineer
Youtube channel:
Use the measure command and select the surface boundary arc. If I can't get it to select the arc, I use curvature analysis and put mouse over the surface.
Can u try this for me sir? It will maybe usefull for u :)
Code:
Sub MeasureRadius()
    Dim selection As Selection
    Set selection = CATIA.ActiveDocument.Selection
    ' Yarıçapı ölçmek için bir daire seçin
    selection.Clear
    selection.Search "Type=Circle,sel"
    If selection.Count > 0 Then
        Dim circle As Circle
        Set circle = selection.Item(1).Value
        ' Yarıçapı ölç
        Dim radius As Double
        radius = circle.Radius
        ' Sonucu kullanıcıya göster
        MsgBox "Seçilen dairenin yarıçapı: " & radius & " birim"
    Else
        MsgBox "Ölçüm yapmak için bir daire seçin!", vbExclamation
    End If
End Sub
Which license is needed for it? I've checked out a bunch of available but to no avail.
