bigTomHanks
Hello Everyone,
There is a debate at work over whether we should measure the pressure(inside a pipe) on a piece of test equipment using psia or psig. A coworker and myself say psig because we can zero the equipment before each use and then work from there. The boss and another engineer say that we should measure it in psia because it takes into account the changing atmospheric pressure. If we zero the equipment each time and measuring in gage pressure aren't we essentially accounting for the changing atmospheric pressure. Our current test equipment uses psig and we want the new equipment to match the old. The software for the new equipment reads and records all data in psia but it doesn't have a sub program that stores the atmospheric pressure and subtracts it so that we now have gage. Basically what I see wrong with using only psia is that if one day the atmospheric pressure is 14.7 and the other day it is 14.8 then if we use psia as our analysis data then we will get different results on the same part if the atmospheric pressure changes. I'm really long winded. Please come in and let me know what everyone thinks.
Thanks,
TheBigTomHanks
Thanks,
TheBigTomHanks
