PeterHerman
- Jan 16, 2007
- 11
I am involved in an investigation of torquing procedures and we need to measure the torque of some 2" b8m bolts in a 40 hole flange. The tension was 27 kips, and the torque using the Sidmore was roughtly 600 ft-lbs. Question is: how do I measure torque? If I go around using the sequqnce, won't I affect the later bolts? Should I check in the tightening or loosening direction? Is there a digital readout wrench this large?
