Mechanical Properties of A588 Gr. A steel 1
sloth4z
132
I am sorry if this is the wrong forum for this but I am at my wits end. Can someone here direct me to, or provide, the following mechanical properties for A588 grade A steel?
Elastic Modulus
Poisson's Ratio
Shear Modulus
Density
Tensile Strength
Yield Strength
Thermal Expansion Coefficient
Thermal conductivity
Specific Heat
all I know is tensile/ultimate strength is around 100ksi and yield is around 50ksi. I can find any information anywhere on the other properties. I have read that the properties change depending on the size and shape. I am using plate less than 1" thick. Any help on this subject would greatly be appreciated.
The yield strength and tensile strength are specified in ASTM A 588, available from ASTM International at:
MatWeb has all but the last three:
And for those, you could use the values for 1020 steel:
Cory
Thank you SO much. Was this the proper forum to post this question?
Yes
Cory
