engresague
In a process of repair procedure qualification, I had today a technical discussion about the next paragraph in the API 1104 code:
10.3.3 Qualification
...... As noted in Table 5, when wall thickness is over 0.500 in. (12.7 mm), the side bend tests shall be substituted for face bend or root bend tests.
The contractor said that this paragraph leaves open the possibility of making two side bend tests instead of face and root bend tests.
The procedures are one for full thickness and one for partial thickness.
In simply reading i can see that the code requires that the face bend and root bend tests should be made, but much appreciate any comments you may add about.
Thanks.
Thanks.
