Wisam Hashim
- May 31, 2019
- 3
hi every body
Iam working in pipeline construction company. I already made purchase order for welded pipes 42 inch api 5L X60 ,14.3 mm wall thickness but the vendor who supplied the pipes make the purchase order for the plates (raw material of pipes) with wall thickness 13.8mm and when I discussed with him about this variation he said this is accepted according to the tolerance in api 5l therefore could any person clarify that the thickness tolerance in API 5L concern the variation in thickness during manufacturing process or it can be consider as permision for vendor to provide the plates (raw materials for lsaw pipes) with a thickness within the tolerance
