1
Hi, I am trying to do a Static Structural analysis for my UAV drone body to calculate deformation, stress, and, strain. Still, I cannot get the correct solution due to a Solver Pivot Checking error.
I tried turning off the Solver Pivot Checking but the deformation is 0. I think my mesh is good except two are very bad (attaching the mesh quality worksheet too).
I also used the status under contact tool to deal with the bad contacts & over-constraints but there are still a couple of zones with the error, is that what caused the answer to 0?
I also did this with another similar model but no over-constraints came up but the answer is still 0. I also tried changing the fixed support to the bottom of my carbon plate and then the plate gets deformed along the Y axis leading it to look like a loaf of bread. I a uploading the images of my problem and model images too. I appreciate any kind of help. Thank you.
#Question #Drone #structural #Mechanical
What is the applied loading?
How is the model constrained overall?
Get rid of all contact elements and just connect the common nodes.
