Hi All, one objective of mechanical running test is to verify oil flow, friction horsepower, and heat rejection to the lube oil.Since the test is carried out under vacuum conditions, resulting in very low aerodynamic thrust loads. It should be noted that thrust friction horsepower constitutes the greatest bearing loss and, therefore how is the calculation from the thrust to full design thrust? Thnks in advance...
