Soupcat
- Aug 28, 2002
- 76
Folks,
Let me run this material selection problem past you, my customer requires perforated trays for medical purpose. The trays will hold 10 Kg of tablets which have been soaked in methylated spirits. The trays will then be stacked 25 high (bottom tray taking a 300Kg loading) in an oven at approx 70 degrees C for 12 hours. After this cycle the trays will be washed in 85 degrees C water and wiped probably with an Iso-propy alcohol wipe. The trays don't need to be USP or EP. US or European pharmacopea but they do need to be FDA approved which will place limitations on fillers etc. Tray is approx 740mm x 420mm x 50mm high. Wall section is 3.5mm. (1 inch = 25.4mm approx) Perforation holes are 2.1mm x 2.1mm at 6mm pitches outer edge to outer edge. I'm proposing to feed in 4 places using hot tips and an insulated runner system. Product life expectancy is 5 years and service cycling can assumed to be continuous. Please see image below. I have ideas on what material I need to use but would be interested in some of your comments.
Kieran
Kieran
