CuriousElectron
- Jun 24, 2017
- 191
For an existing MV cable that is unshielded, if it is desired to perform a Megger test to check the insulation resistance of the cable, would it be advisable to megger it to ground or test from a phase to other phases grounded?
I think if test setup has one lead of the megger device connected to phase conductor and the other to station ground, then we'd be including the insulating air as part of the test. Are there any advantages/disadvantages between both setups?
What about a setup where one lead is connected to the conductor and the other lead is connected to the insulation of the cable? Wouldn't this be a preferable setup over the two above?
The test voltage is 2500VDC. We'd also be conducting a PI test.
I appreciate any feedback, I seem to get conflicting info regarding the test setup.
Thanks,
EE
Thanks,
EE
