We have been having a discussion about the origin and the method behind the use of a nominal load for designing member lateral restraints. The UK code BS5950 states that restrainst should be designed for a force not less than 1% of the axial load. The old code BS449 states this should 2.5% of the axial load. I believe other codes have similar approaches although the percentage varies. I have included the BS5950 text below:
I have done a literature search to try and find a discussion or a reasoning behing this approach but I have been unsuccessful. Is anyone aware of the reasoning behind this approach? Test data? Empirical rules of thumb?
A restraint should have sufficient strength and stiffness to inhibit movement of the restrained point in position or direction as appropriate. Positional restraints should be connected to an appropriate shear diaphragm or system of triangulated bracing. Positional restraints to compression members forming the flanges of lattice girders should satisfy the recommendations for lateral restraint of beams specified in 4.3.2. All other positional restraints to compression members should be capable of resisting a force of not less than 1.0 % of the axial force in the member and transferring it to the adjacent points of positional restraint.
