All
I am working on a high end restaurant and it has a 3rd floor roof deck of a pretty decent size. Currently the roof is designed with steel I beams and a concrete filled metal deck. Above the concrete will be a water proof system and with pedestal pavers.
The architect asked us to remove the concrete and just use the metal deck for support. The metal deck would have ridged insulation and the pedestal pavers would bear on top of the ridged insulation.
The roof deck will be serve as large gathering space. I can get the loads to work but my concerns are vibration and noise from the metal deck. Based on how the roof deck will be used, I cant get past not using concrete....
The architect is adamant about no concrete....
I would like to hear if anyone has had a similar design...
