Metering/Dosing pump 1
skhell
PT
Hi!
I need a small(tiny) metering pump to a small project I am building. In this project I need pump a very small amount of a special oil(about 0.1/0.2 ml/m).
I have found some peristaltic pumps and some other pumps that can do this job:
I am looking for some other pumps that can do this metering/dosing.
Do you know any other types of pumps that can do this job and where can I find them? I am looking for something cheap, or not very expensive.
Hi!
I will take o look on those guys, do you have an idea of what are the prices of their pumps?
You aren't going to get much cheaper than a peristaltic or an FMI pump for this service. FMI make OEM versions that are very cheap indeed.
If you're considering peristaltics, you must not need much discharge pressure. Putting a gear pump or an HPLC-type low-flow piston pump or even a syringe pump on this service would be a waste of money.
Don't forget that if you're only pumping 0.2 mL/min, dead volume in your lines is going to be a killer. You don't want to be pumping for ten minutes before anything comes out!
I have been looking on FMI pumps and they look pretty good, but are way too expensive :(
