analogkid2digitalman
- Jun 10, 2003
- 528
I have a project where we need to heat a small part up for a few seconds in the range of 100-120C. The best approach looks to be a small coil made of a few turns of 18 gauge nichrome wire. Open loop control will probably suffice for this application. Guessing that power needed will be in the 10's of watts. Once I determine the power required it should not require adjustment.
What are the typical methods of powering low power resistive heating elements?
I am thinking of using either:
1. A toroidial step down transformer with just a low value series resistor.
2. Phase chopping SCR circuit on the primary of the step down transformer.
Any guidance or tips from experience would be appreciated.
A 20kW desktop furnace this is not!
-AK2DM
"It's the questions that drive us"
-AK2DM
