Greetings to all Structural Engineers:
I am a MechE and, only by the grace of God obtained my PE. As such, I can only consider myself very fortunate at having a venue, such as this one, to ask what all of you will find to be a much too easy problem. I beg both your attention and indulgence.
Scenario:
1) Given: a "section" of a mild steel structure with welded joints subject to dynamic loading (vis, a 145K gtw ship's hull).
2) The section in 1)(above) contains two (2) flat, rectangular members that are attached to each other at right angles. The approximate width and length of both structural elements are 20mm and 1500mm, respectively. They are both 300mm in height.
3) The subject structure is utilized to provide "stiffening" for the hull plating, and serves no other purpose, and is located within the confines of a cofferdam immediately forward of the main engine room.
4)One of the steel stiffeners has a 3:1 (length-to-height) taper on one side and is fillet welded (all-around) to the other stiffener that is oriented at right angles to it. The taper begins at 200 mm before the joint with the other sitffener
5) Field inspection reveals that in lieu of the 3:1 taper, it has instead been cut with a taper of approx 3:1.5. 3:1 is the design requirement.
6) One of our group's structural engineers looks at this scenario in-place, and asks my opinion. I state that the discrepant end should be cropped and re-newed using the same material, but with the correct bevel. To wit, the much older structural guys has a good belly-laugh, makes some inflammatory remark about my comparative youth and lack of structural knowlege, and then tells the shipyard QC guy that "it'll be just fine the way it is".
7) Later, I ask said structural engineer about how he was able to arrive at his conclusion so rapidly without any calculations, etc.(I do this while visions of those mystifying colorful, structural FEA diagrams flitter around in my head).
8) The response is along the lines of that his long experience is the "mother load" of knowlege behind all decisions that he makes, and also that he has not met anyone who can make these decisions as fast as he can, etc. etc.
9) Is this colleague a "loose cannon"? If not, then I have been straining at ways to figure out similar problems where not as much sturcture is utilized in construction as the design calls for...is there a resource for those in my position, or, is it truly only a lenghty experience that can help me to solve these problems? There should, I reason, be some point where up-to-"x" mm material "short" may work in a structure, but, beyond that point, material will have to be cut and renewed...right?...maybe?
It is now my only hope to have at least described this problem in a clear manner.
Very Best Regards,
(Name witheld due to embarassment)
Scenario:
Very Best Regards,
