Michael Hasie
Is there a standard explaining the tolerance for Maximum and Minimum Clearance holes that can be captured with the use of ISO Washers. Need to know the upper tolerance that can be used for oversized clearance hole.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
