JJAV1983
- Nov 7, 2012
- 35
I recently started working for a new company, I noticed that the default metric title block we are using only has the specifie tolerance as follows:
TOLERANCE +/- 0.1 (mm)
All current and past drawings are dimensioned with 2 decimal places. So for example right now if we dimensioned the width of a plate as 19.10 mm, with the only reference we have in title block (Tolerance +/- 0.1) this width could be made at 19.00 mm or 19.20 mm. But what would happened if the width is 1900.00 mm and we don't need a tolerance as tight as +/- 0.1.
There is no specification for decimal places whatsoever, the only thing it says is: TOLERANCE +/- 0.1
We design from PCBs to low, medium and line voltage lighting systems and every single aspect of the fixture (housings, electrical boxes, brackets, etc). I really think we need to make some modifications to the title block, as the specification is real vague.
I was thinking something like this:
UNLESS OTHERWISE SPECIFIED:
X +/- 0.5
X.X +/- 0.3
X.XX +/- 0.13
Thank you for your advice.
JJAV 1983
X +/- 0.5
X.X +/- 0.3
X.XX +/- 0.13
JJAV 1983
