palk7 EIT
- May 12, 2020
- 142
I have an interior mezzanine (4 sides rectangular box). The framing goes like this with Steel beam, columns and Open web steel joist running perpendicular to the beams. As far as the lateral stability is concerned I can do moment frame in the beam to column lines on two sides, however in the Joist direction spanning direction, could I consider that a tie-joist at the column locations will provide stability to the structure in that direction? No exterior loads other than seismic base shear (will be very minimal as not in a seismic zone).
My question is since I dont have beams in the joist spanning direction could I consider the tie-joist (bottom chord connected to columns) to provide lateral stability to the mezzanine in this direction?
