Mice problem
itsmyjob
2,375
0
0
CA
Anyone tried Intellimouse Explorer 4 with W2000 ???
I do have problem panning and rotation view point in CATIA R12SP4.
Eric N.
catiav5@softhome.net
Hi there.
The problem might be the mouse driver if you installed the ones that came with the mouse.
Make sure you enable standard windows behaviour for the wheel/middle button.
If this fails, try to uninstall the driver, and use the built in windows driver for the mouse.
-Bjod
thanks but..
using or not the default driver does not change anything.
Got same problem with R13 under XP...
I think it is an Hardware problem.. this mice MIGHT NOT BE CATIA COMPATIBLE.
We'll ask DS to check that.
Eric N.
