mfgenggear
Aerospace
- Jan 23, 2008
- 3,119
Question please advise?
Data :the below is an example only not an actual part.
this for my information only & I am doing a test.
Parts that are carburized on gear teeth
Lets say 20 teeth 20 Diametral Pitch 20 Deg Pressure Angle
External Spur gear
Material AISI 9310 Steel
Specification AMS 2759/7 Carburizing & Heat Treatment
Class 2(Requirements) Type 1 (except Endo Gas not Vacuum )
Effective case depth requirement is ~ .010-.025
parts are to be carburized to .022-.027 to allow for grind allowance.
Case Hardness Required 90 15N Minimum @ .004 depth.
core hardness 33-43 HRc
stock removal from gear teeth shall be .004 per surface from
profiles.
Parts are Pre heat, Carburized (1750 deg F for 2 hours),austenitized(1525 deg F for 2 hours )Quenched in salt(400 deg F), subzero stabilized, & tempered to 300 deg F a sample part is sectioned & mounted. then verified with micro hardness (Vickers or Knoop)
a suprficial hardness verification of finished ground gear
90.2 15N min passes.
how ever with the micro hardness check it checks two points under @ .002 & .006 depth.
( should be 732 HK 500 GM (60 HRc)
(Actuall is 690 HK500 GM (58 HRc)
can some one please advise
if the superficial passes then parts are acceptable or should it be reheat treated thanks.
External Spur gear
profiles.
