gotpho
- Nov 14, 2010
- 17
Hello everyone,
I'm new to the laser world and I recently got my hands on a fiber laser cutting head but I don't know how to get a good cut with mild steel. I have been successful with cutting up to 6 mm stainless steel but the mild steel has got me all puzzled. I seem to get a lot of dross/bubbles in the back of the cut and I'm pretty sure it pierced all the way through from the start.
My cutting conditions is as followed
Gas: Oxygen
Gas Pressure: 30-40 PSI
Cutting Speed: 15mm/sec
Pulse: 100 Hz, 10% duty Cycle
At this point, I think I got my cutting speed and gas pressure right and this may have to do with my pulsing parameters. From the literature I read, is it true that pulsing must always be on from the pierce to the finish cut? There's no need to switch from pulse to CW in mild steel? Also it seems most literature suggest higher frequency to 400 Hz and above. Is this what some of you guys do? Any advice?
Thank you,
gotpho
Gas: Oxygen
Thank you,
gotpho
