Good day to all.
Main question: Can PMI substitute a 3.1 mill certificate?
Some Context:
- Specification document states this as a general requirement. Not really mentioning which components requires it or which isn't.
- We are system integrators that integrate components to build hydraulic/pneumatic controls for offshore instrumentation and control purposes.
- All of the components consists of small instrument valves and sensors; at most having 1/2" ports and tube connections (usually 3/8"), unlike piping components.
- Pressures can go upto 150psi on certain loops, or upto 6000psi in other loops though.
- Component's material is mostly SS316.
- Not all instrument manufacturer can provide 3.1 mill certificate for all of their products.
Follow up question:
- Is mill certificate really required not PMI for the above context?
- How to know which components would actually require mill cert. or not? Client rep. is not helping. For him/her, it should be "EV-ER-Y-THING".
All of your insights are truly appreciated. Best regards.
Some Context:
Follow up question:
