I need to miminise solar heat gain through a small transparent plastic window of an electronics enclosure.
I see two approaches: (1) Mimise the solar radiation transmitted into the enclosure and (2) maximise the thermal radiation transmitted out of the enclosure.
Several questions:
- The majority of solar radiation is in the visible light range, but what part of the spectrum causes the heating effect? (Is it the whole spectrum or specifically the IR portion?)
- Would an IR filter help by blocking the IR portion of the solar radiation or would it make the situation worse by preventing the thermal radiation from being transmitted out of the enclosure?
- If the whole solar band causes the heating effect then I would assume that minimising the transmittance of the whole solar spectrum would reduce the heating effect. Is this correct?
I have the option to tightly control the part of the spectrum that is transmitted throught the window and would like to understand this in depth to make the correct decision. Can anyone recommend any books on this subject?
As I understand it a glass window would transmit the short wavelength solar radiation into the enclosure. This is absorbed by the internals which then emmit this energy as longer wavelength thermal radiation which the glass absorbs. Therefore half of this long wavelength radiation is then re-emmited back into the enclosure and the other half emmited to the environment - hence the greenhouse effect.
Several questions:
