minimum allowable flow for centrifugal pump with inverter 2
amazing azza
Industrial
Apr 26, 2017
130
Hello friends, is there any rule of thumb for calculating a minimum flow for an inverter controlled centrifugal pump?
How could one determine this value? My confusion comes from this: given a frequency you can probably find the minimum flow by restricting the outlet valve and watching for noise/temperature. But then again, you could just reduce the frequency without closing the outlet valve and achieve the same flow reduction...
In skid mounted equipment the distances to the first reflection point (90 bend, valve or other restriction) are generally so short that forbidden frequencies are not encountered.
Bill
"Why not the best?"
Jimmy Carter
