The use of Min and Max dimensions are often necessary as overriding modifiers to the dimensional tolerance scheme of a part. I appreciate that PMI is more reliable because of the inability to manually override dimensions from what the solid actually is. The reality is that min and max dimensions are necessary and that the model nominal is typically not the correct value to present as the min or max condition.
How can we use PMI in these cases?
Thin wall castings are a common use case. While min and max are often the lazy mans out instead of a proper tolerance scheme and stack-up, that is not always the case. It would be great if there was an option for defining a shift from nominal. Almost like an offset in CAM. That way it would be associative to the solid faces and consumable by NX CMM.
To date we've tried sketches and regular drafting dimensions in model space. Neither are associative and therefore defeat the value proposition of PMI.
All suggestions appreciated.
