m.wasif
- Jan 1, 2017
- 40
I am procuring Pipe bend with following specification for economizer section of Boiler:
Outer Diameter: 33.40mm
Thickness: 3.38mm
Length of pipe bend: 226mm
Material: A106 Grade B
Design Pressure: 800 PSIG
Design Temperature: 232 Centigrade = 450 Fahrenheit
Bend radius at Center-line of Bend = 40mm
Drawing: Attached
I am facing issue in calculation that what will be minimum thickness at extrados. Supplier is providing thickness of 2.8mm at extrados. I want to confirm that this thickness of 2.8mm at extrados is acceptable or not as per applicable ASME standard. Does any one if possible can share the calculation of minimum required bend thickness at extrados with respect to my conditions.
Thickness: 3.38mm
Drawing: Attached
