Hi, I'm a project engineer at a struct. firm and I was curious about a typical detail.
For this type of connection, the bolts being used are 7/8"Ø.
Reading note 4 under Table 10-9 from AISC 15th ed. it appears this edge spacing (Leh) should be 1 3/4" instead of the listed 1 1/2" (2*bolt diameter).
I'm interested in figuring out how the 1 1/2" spacing was determined and if this is something that we will have to update moving forward.
I've looked through past AISC versions and have not found distinct difference yet.
Right now my only guess is that Table J3.4 was used to determine both the Lev and Leh values which has 1 1/8" min. edge distance for 7/8"Ø bolts.
Thank you in advance!
