Minimum element size and zero element volume error
MGOLOZA
1
thread569-390192
Hello everyone,
Does anyone know the answer for the following thread? I have a similar problem in my case, where I'm trying to simulate the impact of a micro-particle into an aluminum plate by using ANSYS Explicit Dynamics. I greatly appreciate any help regarding this issue.
"I'm trying to model a particle collision between two simple spherical particles. The particles have diameters in the range of 50 - 200 microns. I am trying to run a 2D axisymmetric simulation using Ansys Explicit Dynamics in Workbench 15.0. I can refine the mesh near the contact point using a body sizing mesh with a sphere of influence and the mesh generates just fine (with element sizes of about 1 micron). When the simulation runs though, I immediately get "Zero or negative element volume" errors. If I increase the element size I can get it to run, but I lose the resolution I want to have. I think it might be a precision problem, if the elements are so small that the volume rounds to zero. Is there any way around this? Any help or pointers would be appreciated."
Thanks,
Matin
