Minimum horizontal distance between water/domestic lateral lines for townhouse project in California
kyap88
16
Hi, I am working on a Townhouse project in Sunnyvale, California. Does anyone know the minimum horizontal distance/spacing between water/domestic lateral lines? Thank you.
CK
Something like this help?
Thanks for the reply. This is referring to the distance between sewer and other utility pipes, I am trying to figure the spacing between 1" water service lines or if they can be placed next to each other or stacked. :)
It's up to you and is more of a serviceability / installation and repair issue compared to any "code" requirement, though someone somewhere will have invented a separation distance just to be difficult.
no reason why you can't get 2,3,6 or more and just tie them all together with zip ties if they are PE reels.
Thanks for the reply. I would just assume some distance and the contractor would have the flexibility to adjust in the field.
kyapp88…
Have you asked the City? That's the place to start. The City's requirements must, at a minimum, conform to state law, but they could have more restrictive requirements. I did a quick search on Sunnyvale's website and did not find anything relevant, but they must have something in writing, even if it's only a reference to state law.
For your guidance, I have attached the following in a .zip file:
  • A memo from the California State Water Resources Control Board titled "Separation of Water Mains and Non-Potable Pipelines" (Dec. 14, 2017). This memo is from my electronic archives. I downloaded it in 2021.
  • California Code of Regulations Title 22, §64572. I downloaded this webpage today.
  • Guidance Memo No. 2003-02 from the California Department of Health Services (mentioned in the memo above as being superseded). This is from my electronic archives. I downloaded it in 2021. I also have a much earlier paper copy in my physical archives. I did not look to see if the California Department of Public Health (the successor to the Department of Health Services) has an updated version of this memo to replace the superseded version. I included this document because it has diagrams showing how to separate pipelines based on the then-current regulations. Even though the Guidance Memo has been superseded, I still find it useful.
  • A technical specification from the nearby City of San Bruno, which appears to follow the superseded Guidance Memo No 2003-02. This technical specification is undated, but I downloaded it today, so it is current. Perhaps Sunnyvale has a similar technical specification.
  • Pipeline Separation.zip
kyapp88…
Thanks for the reply and providing the information!
There are specific requirements almost everyone for this. If the inspector finds improper installation, the Contractor will have to correct it.
In California, the minimum horizontal distance between a water line (domestic lateral) and a sewer line running parallel to it is typically 10 feet. This separation is measured from the outside of each pipe.
Key points about water and sewer line separation in California:
  • 10 feet separation: This is the standard distance between parallel water and sewer lines.
  • Vertical separation: When crossing, the water line should be positioned higher than the sewer line, with a minimum vertical separation of 1 foot.
  • Check local codes: While 10 feet is the general guideline, always consult local building codes in your area for specific requirements.
Thanks for the reply. Really appreciate you guys support and feedbacks.
There are specific requirements everyone for this. If the inspector finds improper installation, the Contractor will have to correct it.
The OP though was asking about separation between the same water supply service pipes, not water to sewage.
the second last row shows water. It would be the same for a small dia water connection
If the OP was referring to clearance between multiple water laterals there is no prescribed clearance, however good engineering would have them spaced in a way to allow them to be accessed relatively easily, maybe 1 or 2 x diameter separation at the same level
The word "domestic" in the OP refers to sewage.
Maybe it did, but then post no 3 he said "I am trying to figure the spacing between 1" water service lines or if they can be placed next to each other or stacked. "
Post No.3 3 also states: "This is referring to the distance between sewer and other utility pipes, I am trying to figure the spacing between 1" water service lines or if they can be placed next to each other or stacked."
Thank you all. Another question, what is the minimum distance between water service line and the 2' wide trench (telephone, catv and elec). Thanks!
Just make the trench 1" wider and lay it down the side?
What is this? - 20 questions?
Thanks. Not sure the 1" is referring to. I am talking about the water service and dry utilities joint trench spacing though.
I was saying if you've got a 2 feet wide trench for all that stuff, just make it 1 inch wider and run your water pipe down the side of it.
If its a trench then the utilities will need to all be water proof as it gets wet underground when it rains, so a water pipe, even if it leaks, won't cause any issues.
To me most of these questions are not "code" questions, but simply common sense about access in the future if you need to dig one of them up and repair it or ease of installation.
If you really want two trenches then its all about one trench not collapsing in on the other so say 3 feet?
