  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
MINIMUM PERCENTAGE OF REINFORCEMENT IN PILES 2
cdous
37
0
0
SA
Would appreciate if someone indicated the minimum precentage of reinforcement for piles demanded by eurocodes
Buildings: [5.8.4 EN 1998-1]
Bridges : [6.4.2. EN 1998-2]
To these paragraphs in certain areas (i. below pilecup and at soil strata changes with stiffness module ratio more than 6) you should design as potential plastic hinge regions. That means that in buildings you should apply (DCM) the paragraph [5.4.3.2.2 EN 1998-1] that requires minimum longitudinal reinforcement 1% and maximum 4%. Also design for critical regions (i.e. stirrups distances, volumetric ratio etc).
URL:
