canwesteng
Curious how others approach this - I have a block of concrete used largely as a chunk of mass to prevent overturning/uplift. The design works for internal forces as plain concrete. I would never just pour a block of concrete without bar, since it could crack and fall apart, but if I add 0.2% bar it becomes a tremendous amount of bar on each face. I usually reinforce say the outer 6" at 0.2% and call it ok if it's looks reasonable, or possibly assume a crack occurs somewhere and check that the bar works as interface shear reinforcement. Are there any other reasonable approaches?
