afa13
- Jul 19, 2012
- 56
What is the minimum slope one can use on a sewage system with less than 25 fixture units?
I know that 1% is acceptable and sometimes 2% is the least recommended...
can you use on that system a pipe with 0.5% slope?
And let say i used the manning formula to see if a given slope is acceptable..how should i analyze the answer? should the velocity be below 6fps ?
