Beo81
Marine/Ocean
- May 8, 2009
- 10
According to IEC Standard, maximum and minimum short circuit levels should be calculated.
I am using EDSA, and can not see that there is a module for calculating minimum values. There is however the 30-cycle steady-state calculation, can this be used?
What do I need to do in order to get correct minimum values?
Thank you all
Thank you all
