Hello All, We have a underground structure that has an arched concrete roof. The roof is in complete compression and transfers the loads to the exterior walls. Someone had mentioned to me that we need to provide at least 1% reinforcement ratio because its a compression member. This arched slab spans 70 feet and is 40 feet wide. Does anyone agree that it needs to meet the minimum column reinforcement ratio of 1% per ACI or can I go with a lower ratio? I have always believe that refers to tied columns. Bearing walls are in compression and they don't require reinforcement ratios that high.
