h-badawy
- Jan 8, 2015
- 132
Dear experts
In the Egyptian code the minimum slab thickness to put only one single layer of reinforcement is 16cm because of shrinkage otherwise you have to put second layer.
I don’t know what is the corresponding value in the ACI-code maybe it is same.
my question is what is theoretical reason for this value(16cm) and also if we don’t have any tension force and we did an ideal curing during construction so what is the need of the shrinkage additional layer ?
Thank you
Thank you
