I know the code is a minimum operating pressure of 20psi at service connections, but what are the restrictions against low pressure along the course of the water main? In our case we have a private 4" main that is functioning more like a transmission main feeding a camp with demand of 30gpm. It is tapped into the public system with 35psi at POC. Our review shows the existing line to have localized pressure drops along its length of <20psi but due to a lower elevation difference at the point of delivery the pressure is nearly the same since the elevation difference negates the friction losses. We are planning to add air release valves along the major high points, but we are trying to prepare for potential client pushback against a 6" replacement recommendation.
