Jonathan Lessard
Hi guys I have a bystronic 3015 with btl 2800, I have change all the mirror except for 2, to me they look very intimidating
The 2 (position #1 and #4)that I need to change are the end mirror and the output window. Do I need to know something before replacing them since there is a lot of adjustments screw in this area or I just change them as I did with all the others? Or if there is a procedure or something I would appreciate to get it.
Thank you
