Jun 13, 2009 #1 maurelius Electrical Oct 15, 2008 27 0 0 GB After a crash, SolidEdge v18 now refuses to show the window that displays after you use the inspect menu to measure distance, angle etc... I have tried re-installing and the latest SP but nothing can get the window back. Anyone had this before? Thanks
Jun 13, 2009 #2 donyoung Mechanical Oct 8, 2005 1,018 0 0 DE Hi, usually deinstall/reinstall will leave the registry untouched and thus everything is unchanged. To get the window back you can try to delete this key (only this) SE must not be active: HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version xx\Part\MeasureDlg xx = your SE version. If that does not help you can delete the whole key: HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version xx thereby loosing all your settings. SE will recreate the key upon start. HTH dy Upvote 0 Downvote
Jun 13, 2009 Thread starter #3 maurelius Electrical Oct 15, 2008 27 0 0 GB Excellent, thanks Don. Your're a star Upvote 0 Downvote
Jun 13, 2009 #4 donyoung Mechanical Oct 8, 2005 1,018 0 0 DE Hi, thanks for the kudos. Now that all is working as it should it's time to export the whole registry key HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version xx to a save place. When later on something is wrong you can delete the key and restore it by double clicking on the saved .reg file dy Upvote 0 Downvote
