Mitsi and wonderware
knutknut
Industrial
Feb 1, 2004
11
0
0
GB
Has anyone used Wonderware with a Mitubishi FX. We have a wonderware system on a SATT35, and I want to add an FX into the system. What do I need?
We've done this with Wonderware using the TOP Server's Suitelink interface to Wonderware and the Mitsubishi FX driver. It has a Stattbus driver too, but I am not sure if that's what your using. Just configure the thing to connect to your Mits and set-up a Access name to talk to the Server and you should be ready to start adding tags in Wonderware.
You can get there stuff at
Thanks for the info
I have installed the topbox software using the sattbus driver as suggested and it is now working a treat
