I came across this article here
that describes a way of controlling outdoor air flow accurately.
TLDR: This strategy relies on maintaining a fixed differential pressure across the outdoor air damper, to ensure the minimum outdoor air volume is maintained. Outdoor air damper is set at a fixed position. The return air damper OR the return fan can modulate to maintain the pressure across the outdoor air damper. The outdoor air damper is like a fixed orifice, therefore once the correct differential pressure across the damper is determined, maintaining it will always ensure the correct air flow.
Question is, does anyone use this? I worked for two different consulting firms here in Toronto, Canada and never came across this strategy.
