GeorgeGrande
Chemical
Case description:
Saturated brine (9 bara) is flashed (5 bara) over a valve. The two phase fluid is than mixed with cold brine (<100oC) discharged from a heat exchanger.
What we see (or hear) on field are heavy and noisy bumps that seem close to take the pipe out of the concrete.
1. Are there any flow elements that can help with that kind of mixing?
2. Are there any rules of thumb for the upstream minimum length for the two phase before it mixed with the cold fluid?
3. Any reference/paper deals with that kind of mixing?
4. Any good field experience?
