mixing PP/carbon 4
finfin11
Materials
Nov 6, 2012
3
I need to mixing PP with carbon, but composition of PP < 10 %wt. will be prepared with different percentages PP–carbon 6:94 and 8:92. whether it can be formed into a rectangular plate? Please tell me, how about the procedure?
do I need a solvent for PP? does anybody know a good solvent for PP?
thanks
By PP i guess you mean polypropylene. If so, no, there are no solvents.
What do you mean by carbon. It comes in many forms, however I doubt that polypropylene can we it out at that quantity if mixed with molten polypropylene.
Pat
for site rules
Hi Pat,
thanks for your answer
I will mixing polypropylene + carbon black powder, but composition of PP < 10 %wt. will be prepared with different percentages PP–carbon black powder 6:94 and 8:92. whether it can be formed into a rectangular plate?
Please tell me, how about the procedure and method?
I think I already said it can't be done.
I think for carbon black it is probably difficult to get more than 40% into PP. Maybe less.
The method is usually feeding both materials into a twin screw extruderthat melts the PP and mixes the carbon powder into the melted PP
Pat
for site rules
I think the only chance you have to make make such a material is to start with PP powder with a particle size of 5 micron or less, blend the powders together and compression mold at high pressure and temperature.
Another way to put this is to go to the kitchen and weight out 95g flour. Add 5g water and try to mix that into a paste. You'll need more fluid phase.
Chris DeArmitt - PhD FRSC CChem
Plastic & Additives Webinars
Instant Downloads & Inexpensive
CP at 5% there still will not be enough volume of PP to form a binder to stick the carbon particles together.
Pat
for site rules
Hi Pat,
Thanks! A compliment indeed coming from you. My mind works in simple terms like that. Easier to relate to than equations and obscure theories.
Chris
5% is a very common binder level when simply binding particles together. It will simply not be as strong as a mixture with more binder. The OP has said nothing about the purpose of his plate. Carbon black can be pressed into a plate without any binder (as can flour, for that matter).
It is possible to dissolve PP. For example when you want to measure the molecular weight by GPC they heat it in trichlorobenzene to dissolve it.
In some work I did we avoided chlorinated solvents and used a MARSX Microwave oven accelerated reaction system for extraction from CEM where the solvent was 25 ml of a 30% n-Hexane, 70% Ethyl-acetate.
I am not 100% sure that dissolved the PP, it did definitely swell it.
thanks for all
I will try your suggestion
and I still receive more suggestions
